Hpop fittings?
PSD715
Alamogordo NM
Does anybody have any idea where to get these?
I have another 7.3 that's literally only missing those, or it'd be ready to drive
PSD715
Alamogordo NM
Is there any difference in fittings between the 15 degree and the 17? Because they only have the fitting listed under the SD section.
Parker, TX
The SD pumps used the quick-connect fitings. The OBS used the regular straight thread, o-ring boss type elbow fittings (I forget which dash size). Cheers!
Tom S
A good hydraulic hose shop should have that stuff if you are looking for the obs ones.
m j
BC Canada Eh!
the head is -05 ORB, only reason I know that is from making the adapter to test pressure.
the lines are a common JIC, I think they are -06 but any hydraulic shop will have everything you need
probably need a-05 orb to -06 jic for the head side, and I would guess either a -06 orb to -06 jic or a -05 orb to -06 jic for the pump side
only reason I suspect the pump is -06orb is the magasine article showing the SRP1.1 details states they machine the pump from -06 to -08 orb fittings to get stronger threads
