hvac troubles
Short Bus
kansas
I have a truck that the blend door is not operating properly. I have eliminated teh control cable as it operates properly switching from hot to cold. The problem is that the blend door only moves for about the middle half of the transition from hot to cold. so no matter if you have it all the way cold its still open 1/4 of the way allowing hot air to blend in. If you have it all way to hot, its 1/4 open on the cold side allowing cold air to blend in and well at these temps that equals 0 heat. There does not appear to be any debris in the way preventing it from moving. in fact if you hold it all the way shut either direction it opens back up to 1/4 open when you let go. I am stumped, anyone had a problem like this?
PsRumors
Cartersville, GA
Sounds like the cable isn't secure on one end. If the cable & sheathing are allowed to move you will not get the door to swing its entire arc.
Short Bus
kansas
I think that was part of the problem. After I put it back together it worked a bit better.
