Injection pump
Jake
TEXAS
What is the average price for a stock pump? And installation? Does the cab have to come off? How long ? it is on my buddies truck, p 0088 code that is intermitten with loss of power with it. Truck has 160 k miles on it.
Sent by smoke signals
Jake
TEXAS
Of yeah and recommendations for shops in north texas south oklahoma ?
BFT
southern cali
Most shops range by the hour or the job. I'm sure someone will chime in and give you a heads up on a near by shop.
FWIW, you will need a bit more then just the pump (copper crush washers for the banjo bolts, up pipe to turbo gaskets, coolant if the ab comes off...Etc). It's a full day job at minimum. 2-3 hrs at most to pull the cab. 1-2 for removing turbos, fuel coolers and pump and probably installing new pump. Another 1-2hrs getting everything back on and what not. 2-3 hours to put the cab back down and top off fluids.
I don't know how much they charge out there, but in Cali it's $90-120 an hour for shop time minus parts. I guess you can say about 1k for labor at most, don't quote on that though.
Jake
TEXAS
All this makes me really like my 7.3....
I can't believe all this has to come off to change the pump out! oh well. I don't have a lift at the house so I don't even want to mess with it since it seems like to do anything more than change the oil on these the cab is coming off. I will call CED, They are all the way north OK that may be further than they want to go. They are basically on the Red river
jkidd_39
NW Arkansas
Did you have any injectors go down?
I don't know if it may be preventative. But Ford recommends that if you have 2 or more injectors go bad that you should replace all 8 a d the pump.
This may be something to look into. I've been hoping I have two injectors pop so I can get 8 new ones and a new pump on ford's dime.
Sent from my iPhone using Tapatalk while pulling a 36ft gooseneck and not paying attention to the road.
BFT
southern cali
The cab doesn't have to come off, I'm jut saying most places will.
