Power Strokes
7.3 Tech
injector advice
[QUOTE="golfer, post: 243264, member: 266"] it's the injectors...the poppet valves within them actually... the poppet valve is what seals the HPOil inside the injector...when these valves wear...during cold starts (cold, thick oil)...the oil can't flow through these (worn) valves very well... once the oil (warms up &) thins out, and the engine heats up...the engine may run really good, since the thinner oil can now flow through the worn poppets more freely... factoring in the # of miles, & the (hard to start when cold, low power when cold(?)) symptoms...your symptoms are verbatim of just normal, higher mileage injectors... [/QUOTE]
Won’t start
Latest: psduser1
Yesterday at 11:33 AM
7.3 Tech & FAQ
GT37 Turbocharger w/10 blade turbine, billet comp.
Latest: hskfab
Friday at 1:24 PM
Engine and Drivetrain
Hard steer question/issue
Latest: psduser1
Jun 5, 2025
7.3 Tech
B
WTS/WIF light flash and stall issue
Latest: blickcd
Jun 5, 2025
T
2013+ steering gearbox in older trucks
Latest: TPOLO
Jun 4, 2025
Power Strokes
7.3 Tech
injector advice
