Injector Giveaway!
RamzTrk
Since you have all the flow benches and nozzles, can we some Proving ground proof? I'd like see stock flow bench tested stock,35,75,100 and then 155 then 175 the 195s. Proof that too large nozzle on too small injector will not help flow. Then dyno each setup to see what real world difference injectors and nozzles make.
Pizza pig
MD
What would you like to see? We can build whatever you want. There are limitations, and there are only so much a nozzle can FLOW. Thats what a lot of people dont realize. the stock nozzle is only capable of flowing about 170cc of fuel. you can cut all you want, but flow is flow. You can machine the body to hold however much fuel you want, but it wont all come out the nozzle at max pulse width.
We did some testing, at 4000 rpm, and 2.4ms we get 152cc out of a stock injector with no mods done to it, and a 30% nozzle. The injector next to it was the same but a 100% nozzle, that flowed 160cc. Flow is flow. We are going to be doing some testing here soon with the RCD high volume pump and 210+ cc injectors and dyno results.
