injector leak
missfire unload
alberta
Good Day
i have been chasing p1121 i changed the hpop, lines, ipr and ipc, the reason i did injector o rings last year so, i did a air test on the injectors put 100 psi into each head, and found air leaking from the spout of an injector before i spend more $ does anyone know if that is normal or what to do to fix it
