Injector noise?
Powerstroked6.7
Washinton
After I had my 15' injection pump installed, I started noticing injectors or valves rattiling not sure what I'm really hearing it happens if I give it to much gas before the turbo spools
Powerstroked6.7
Washinton
Not sure, do you know how this is done, the only thing I've herd about changing this pump out is that it is a timed pump
Mesa, AZ
Using the ford ids you need to tell the truck its got new hi pressure stuff in it. It resets the tables for the vcv and pcv valves. Just a thought. Ive never tried without resetting them so i dont know whatll happen if you dont.
