Injectors, idm, or other
OuchThatHurt
Neah Bay Wa
Evening fellas. My 96 7.3 has been feeling doggy lately. Low on power, has a light shake at idle... like if I were to unplug one spark plug cap on a gas engine.
Replaced a bunch of stuff, and came to the conclusion it needed to go somewhere to be hooked up to a laptop. The gentleman tells me #' s 2,3,6, and 8 injectors are weak (contribution test).... but may be an idm problem.
My buzz test at home sounded fine, his buzz test tested same as the contribution test.
Truck has 300k so I know the injectors fought the good fight. Just want to make sure I'm not throwing more money at parts... that don't fix anything.
What do y'all think?
I have a swamps idm on the way right now.
OuchThatHurt
Neah Bay Wa
I drove the truck an hr away to this shop. It doesn't drive terrible just a total turd. I can't imagine it hardly running wth 4 injectors having issues
DEEZUZ
NO PUKESTERS
NWI
Any smoke or hard starts?
Could be worn on fuel side, not oil side.
I never trust contribution test on 7.3. it's break out box or nothing
ghohouston
Lewisville,Texas
Could be uvch's, could be low fuel pressure, could be many things. 300k on injectors is alot though, and likely the problem. I definitely agree with CTC, all 8 are probably due for replacement.
OuchThatHurt
Neah Bay Wa
New pigtails, new big cover gaskets, new uvch' s. New glowplugs, new gp relay all ohm'd.
Also new fuel pmp.
All I can say is once in a blue moon the truck will 100% stop shaking and idle absolutely perfect for about 5 seconds.
OuchThatHurt
Neah Bay Wa
I'm thinking I'm gonna change both of them when/if I do injectors.... I'm sure they are original. If the idm doesn't fix my issue muse well do it all
OuchThatHurt
Neah Bay Wa
So I have a video of the blow by. I'm a marine diesel mechanic so in my opinion it's almost none... but if like someone knowledgeable to take a look. For some reason I can't up load the video. I can send it if anyone is interested in reviewing it
DieselDC
Get new injectors. Yours are worn. You’ve done everything else. Let’s see what the swamps idm does.
OuchThatHurt
Neah Bay Wa
Waiting til end of next week to get idm, and just ordered full fo4ce 250/100's...��������
