Intermittent Coolant Leak
imajerk123
I have what appears to be a leaking heater core. The wierd thing is that it only leaks when the heat is turned on.
Coolant smell from the dash and a fair amount of coolant leaks from teh A/C drain.
Turn it to full cold or to off and the leak stops. Not sure when it happened since its been hot out all summer. I haven't been able to locate a control valve for the heater core flow, just want to make sure im not missing anything.
Anyone had to replace a heater core in one of these? Anything else to replace along with the core?
