JL C3 570 convertible 5x7
Grey_Matter
SOMD
has anyone tried to fit them into our trucks?
according to Crutchfield they do not fit in the factory location, has anyone made the attempt?
I'm curious what keeps them from fitting, and if there is a work around to get them to fit
Grey_Matter
SOMD
although after reading alot of the audio threads i think its safe to assume most of you dont use good audio equipment
scparrish
DFW Texas
That's a pretty ridiculous assumption.
If you are so set on these then order them. If they don't fit return them. Pretty simple.
Jomax
Arizona
I'm happy with my Sony system. Works good enough. Never tried those speakers.
444whitehorse
Obs or SD? If obs, I'd look at mounting depth. I had an old set of 5x7 pioneers that I had in boxes for a single cab brick, they were too deep for the rear corners of my cc obs
Sent from my Z958 using Tapatalk
mikes02ls1
I have JL Audio C2 650 up front and C2 5x7 in the rear with a JX400/4 amp. Im up grading to Audiofrog GB10, GB25 in custom pod on the mirror access panel, then GB60 in the door. Rear will be GB60, with a Audison AP8.9 DSP/Amp. Can't wait to hear what it sounds fully tuned.
