JTR Cap 218HT Home Pro audio sub
powerlifter405
Butt Town
Selling my JTR Captivator 218HT. The 218 was originally developed which then morphed into the 4000ULF. http://jtrspeakers.com/captivator-218ht.html JTR develops systems for pro-audio and has transitioned to the home market. He is in Chicago if you want to see his offerings.
Dual 18's cab, 1400 watt ICE power amp. The large cab makes so a huge power supply isn't necessary but if you look at the specs, it works well w/in it's design parameters. The drivers are custom eminence 18's built to Jeffs specs using a 215oz magnet each.
I changed over to dual 2400's so the 218 literally sits in a corner waiting to be used.
The drivers and amp are in great shape. The cab has some white paint scrub in one corner from rubbing up against the wall at the previous house. Its not bad but it's there so i'm pointing it out.
If you're not "into" HT home theater or clear, clean HO audio then you're missing something. It will destroy anything you get at a box store and exceeds many other top tier brands for SPL plus it has extremely low distortion at those levels.
There are some threads on the AVS forums "subwoofer" sub-forum.
In NE its a big a$$ sub but the trade off is couch shaking lows from Star Wars, irobot, etc..
$1,800 OBO
