Looking for 7.3 parts
giannid
Chardon Ohio
I've got an extra International 444e that I need these parts to convert it to a powerstroke superduty. It's a spare engine so I'm not in a hurry for the parts. I'm located in Chardon Ohio 44024 so they would have to be shipped or close enough where I can pick up. Please pm or email me at gfdifranco@gmail and let me know what you have and how much. Thanks
Drivers side exhaust manifold
oil pick up tube
oil pan
oil cooler with both housings that bolt up to block and front cover along with all bolts
hpop reservoir with mounting bolts including top/lid
hpop cover plate that holds ebpv
ebpv tube
fuel line to head adapters
engine fuel lines from fuel bowl to heads and fuel bowl to truck
fuel bowl
fitting that goes from the passenger side engine to heater core hose
engine wiring harness with valve cover mount
automatic transmission adapter plate
Magnum PD
VA
I got a couple of those things. Do you need the SD intake spyder?
giannid
Chardon Ohio
Didn't know the pick up tubes were different. The one that came off my 2001 SD fit the 2000 444e perfectly. How can you tell?
Magnum PD
VA
My oil pickup tube is for a 96. Comes off the left hand side of the front cover
giannid
Chardon Ohio
The engine ended up getting sold so I'm back to looking for the parts. Not in a big hurry though as it's a spare engine.
