Looking for info on h&s canned tunes and related questions.
94forddiesel
Ashaway, RI
I've been out of the 6.4 game for a while. But I just purchased a 09 f350 zf6 truck. Was bone stock till yesterday I got my mini maxx unlocked and installed full exhaust. From my previous 6.4 I had some bad luck. My main question is what's the best canned tune to run? What should I be looking at for max timing and max egt. When I installed the *** off tunes I chose the easy tuning, left low boost fueling at default and have only ran it on stock. Thank for any help just want this one to last. Figured atleast leaving it on stock and getting rid of the *** would help.
Easy cycles the egr at idle. Not really a lot to hurt on a zf truck. stay out of the HD 300 if you want head gaskets to last but really the tuning isnt that bad. I would run the mild tunes myself and keep the low boost fueling under 3
94forddiesel
Ashaway, RI
Ten four. Yeah I cracked pistons on the last engine. So trying to avoid it as much as I can with this truck. So should I retune it and drop the lbf to 1 or so?
anything under three. you want a bit of response but not a lot of smoke.
