Looking for turbo suggestions
08Monster
Question to see what you would all do. I have a 2007 with a stage 3 powermax in it, motor is pretty well built, all the fuel components are there, and has stock size injectors.
I'm not sure if it's the turbo causing my towing issues, or the truck but I CANT tow. I can't even use cruise in my top gear at say 70mph with 8k behind me. Dogs out and starts loosing power and has to down shift and run at 2600rpm to go 70. It will than shift back up to 5th, and repeat. I can't even pull a small hill and not loose speed. Boost numbers cruising empty are higher than they are towing at the same speeds. Mileage is terrible.
What turbo would you pick that can still tow (in my top gear preferably), make good power (500+), and drive nicely? I plan on going bigger injectors, I would like to touch the 600+HP mark.
Sent from my XT1585 using Tapatalk
Nick7.3
I would do a 190/30 and a stage 2 kc turbo seems to be a popular combo. But a stage 3 on stock sticks is pretty big. If i where to stay with stock sticks I'd just run a 1.5 kc turbo
kwelch08
corpus christi TX
This is the combo I have and I tow a 13k-15k (depending how loaded down we are) fifth wheel from job to job without a problem at all.
08Monster
How's mileage, power, towing manners, etc
shmoozer
A stage 1.5 or 2 KC or barder would tow far better with stock sticks than that stage 3 powermax. That stage 3 is far too big for the limited amounts of fuel.
08Monster
Do you think that's my issue, or do I have something else going on as well. It's a DOG trying to tow. If I would upgrade injectors and keep the stage 3, would it tow better? EBP seems way high also. Almost always a 2:1 ratio, sometimes 3 or 4 to 1. Idle is EBP 3, boost 0. Light driving around town I see EBP 20, boost 5-8. 70mph I see EBP 29, boost 15. Wot EBP is 39, boost 29.
Could be a faulty ebp sensor not helping things either.
slc6oh
Utah
im on a stage 1.5 and stock sticks, love it. every part about it.
if for some reason i ever need injectors, ill bump to 190/30s and a stage two.
kwelch08
corpus christi TX
Mileage is pretty good haven't really tracked it just know I can drive back and forth to work that is 22 miles round trip for two weeks on a single tank. Towing is awesome it doesn't like it when you drop the rpms below 2k though but no big deal. Around town it's an absolute blast.
kwelch08
corpus christi TX
08Monster
In my top gear I'm at about 1800rpm at 70 so maybe that won't work for me either.
shmoozer
I think it's part of the issue yes. Not enough fuel to drive the charger is going to make it a little doggy. Are you lifted at all? Wheel and tire size? What are your rear end gears? That could be playing a part in the issue as well.
08Monster
Leveled, 35s, 3.73s
