Lost Headlights
Viking
Minnesota
I checked all fuses and replaced the bulbs. This happened while parked. No low beams or high beams but I do have driving, turn, hazard and brake lights. I have not taken the power dist. box out and checked the back side for grounding issues or any melted plastic.
Has anyone seen this?
Viking
Minnesota
It's a 2004, I couldn't find anything searching the net. I will definitely check the switch asap. Any way to bench test it? I'm not too up to speed on multi meters or power probes.
THANKS!
Viking
Minnesota
So after checking wires and putting in a new switch I am now going to check the multi function switch. My headlights mysteriously came back on without a reason. Here's to electrical fun! :toast:
fastersteve
Stock wiring or an aftermarket full voltage harness?
I had the GOS racing harness on mine, it kept burning up the connectors.
