Low Brake Fluid
stroked16
Had a few dummy lights come on over the past few days. 2016 6.7L 22k miles.
Traction Control needs servicing
ABS Lights
Low Brake Fluid
Checked brake fluid reservoir. It was at minimum level. I topped it off and so far, no more dummy lights. Can't figure out how I lost so much fluid as I have zero leaks.
8WR_ZJ
How worn are your brake pads and rotors?
79jasper
skiatook, Oklahoma
Yep. Everyone thinks oh it's low, let me "top it off."
Brake fluid does not just get topped off. Level goes down as pads wear. Somewhat of a "indicator."
If pad thickness is fine and you're still having to add fluid, you have a more serious problem, and should get it checked out.
Brakes are life and death.
Sent from my SM-G892A using Tapatalk
stroked16
I'll have to look at them. No noises but I'll be sure to check them out. I've never had a vehicle burn through brakes in 22k miles but stranger things have happened.
8WR_ZJ
Yea that would be a little crazy! Maybe it wasnt full from the factory? Brake pedal feels fine?
stroked16
Brakes feel fine. Other than the dummy lights, nothing feels out of the ordinary at all.
Jomax
Arizona
I hope your brakes are good! I’ve got 90K on my original pads and rotors and they’re still 30% pad left...
Lucky. I went thru 2 sets of pads and two sets of rotors in 118k miles. LOL
