Power Strokes
6.4 Aftermarket
Mild Reliability Build (Am I Missing Anything)
[QUOTE="B585Ford, post: 994714, member: 5497"] Especially if you don't plan to do pistons, I lean towards the ported intake manny...in theory, it should allow the back cylinders to run about the same temp as the front cylinders so it might reduce the chance of cracking a piston. Should help spool up too which is nice when loaded. As mentioned already, definitely 6.0 exh manny and the up pipes of your choice. [/QUOTE]
Hard steer question/issue
Latest: psduser1
Yesterday at 8:52 PM
7.3 Tech
B
WTS/WIF light flash and stall issue
Latest: blickcd
Yesterday at 6:23 AM
T
2013+ steering gearbox in older trucks
Latest: TPOLO
Wednesday at 11:09 AM
J
15 cab on 08
Latest: jeretl
Monday at 2:38 AM
Aftermarket Super Duty 1999 - Current
S
F-350 Dually tire size
Latest: Smokin 6.0
May 30, 2025
6.7 Tech & FAQ
Power Strokes
6.4 Aftermarket
