retrosolutions
- Joined
- Jul 13, 2011
- Messages
- 3,021
- Reaction score
- 0
Mini BiXenon HID Projectors for Retrofitting projects are on sale while supplies last!
The Mini BiXenon Retrofit Projectors are a great upgrade for those looking for the next level in high-performance lighting not possible with factory lamp optics and standard conversion kits. Now these same projectors are available with easier adaptable solenoid connections, stronger mounting threads and better beam pattern than similar projectors offered elsewhere at premium prices.
These units provide excellent performance, small size, ease of installation, and low cost compared to traditional retrofitting of projectors. These projectors make retrofitting a project to getting performance HID projector lighting as easy as it can be. These projectors will use the same hole in the head lamp's that the stock bulbs fit through, and work great for H4, H7, H11, H13, 9003, 9005, 9006, 9007, 9008, HB1, HB2, HB3, HB4, and HB5 headlamps. Some specific vehicle applications may require modifications to allow for fitment or proper mounting, but always feel free to ask customer service for help with your vehicle application.
Installation requires disassembling of the head lamp housings, inserting the threaded mounting shaft of the projector through the pre-existing hole in the back of the head lamp's reflector bucket, tighten down the mounting hardware in the rear with the included hardware, and you're virtually done. Some specific vehicle applications may require modifications to allow for fitment or proper mounting, but always feel free to ask customer service for help with your vehicle application.
SPECIFICATIONS:
- Max Depth: 132mm (5.20 inches)
- Max Mounting Depth: 120mm (4.75 inches)
- Max Height: 75mm (3.00 inches)
- Max Width: 84mm (3.30 inches)
- Glass Lens Diameter: 2.5 inches
INCLUDES:
- 2x Mini H1 BiXenon projectors (Low/High Beam Function!)
- 2x Mini Shrouds
- 2x Solenoid input pigtails
- 2x Clear glass lenses (pre-installed!)
- 2x adapter plates for H4 and H7 applications
- 2x small size rubber washers
- 2x large size rubber washers
- 2x Locking rings, assorted hardware, and bulb retainers
- 1yr. manufacturer's warranty on projectors and full packages
- Installation guides available upon purchase
* Can be combined with equipment for full installation packages
FITMENT NOTES:
- Projectors fit most applications easily, please check your application with customer service
- Projectors use H1 HID bulbs only
Only $85.99 per pair/set!
No discount code is needed to enjoy the savings on these. Just click on the link here to save:
www.retro-solutions.net/product-info.php?H1_Mini_BiXenon_projectors-pid762.html
SPECIFICATIONS:
INCLUDES:
- 2x Mini Shrouds
FITMENT NOTES:
