modified dt360
swamp_ratt
hudson, wi
Selling my dt360 I built for my truck. No bull****, no games, need the money! I have a good amount more into it than I'm asking!
160k miles, 50 psi warm oil pressure, fresh ported and polished head and cut for bigger valve springs, valve job, 500cc p7100 and 5x20 injectors by contagious diesel, custom Manton pushrods, pbm valve springs set at about 160 psi seat pressure, custom p7100 adapter and adjustable gear, ATI super damper, 2 inch id stainless pipe to make header, holset ht4c 85mm turbo. Probably a few other things I'm forgetting. I was going to run a holset hx52 on the manifold, but it needs a new chra ($800 from majestic turbo in Waco TX) and the ht4c. Projected to make 900 plus at the wheels on this setup. Pump is set at 4300rpm and currently timed at 30 degrees. Runs amazing! $5500 takes it all right now!
jimdawg185
Good luck with the sale C. I would be all over it if I didn't have a cracked block on my sick fo...
jimdawg185
Lol! My block has been cracked for a year.
FYI I have a perfect truck for this engine. Comes with a spare motor, and all the adaptor plates to put this engine to a 4r100. Only thing missing would be a pcs.
psduser1
on the road
Swap out a 6.4.....
jimdawg185
Swap out a 6.4.....
Lol, no, my Excursion. Its just been sitting and I really want a 6.4 shorty race truck.
There is a motor being built for my 6.4 currently. Just need some more coin to help finish it.
psduser1
on the road
It would be fun, you must admit!
Ex would be a good project, tho, too.
The dt is priced right for sure!
if you got this motor and ran it to its potential, and adapt it to the 4r, it had better be the strongest built in the world.. lol... i have seen everything that was done to the motor. stock head bolts hold i think around 100psi and i think the homo planned on running it around 800hp with compounds as a DD. it would make the ex scoot!!!
