Moisture in vacuum lines
Winchester, VA/ Bloomery, WV
So I had another thread about my brakes acting up in cold weather. I was given an idea that there is potential moisture in the vacuum lines and it's freezing causing my issue. The idea to remedy this is to purge the system with electrical contact cleaner. Would using the vacuum line off of the brake booster be my best bet to clear the system?
KBMKVIII
Texas
Sounds like a option but what is the condition of the lines?
Cracked/dry?
