JoeDaddy
Im posting this because i feel like a lot of you (like me) either went the easy route and mounted in the dp or never mounted at all.
I finaley tapped mine into the drivers exhaust manifold saturday. I set aside about 2-3 hours in my mind. LOL
It took about 15 minutes. I spent more time getting out and putting away the tap set, drill, bits, extention cord and lube spray.
It is harder to weld a bung on the dp than tapping the cast iron mani. Just use a good sharp bit and lotsa spray. Piece of cake!
