Dieselboy
- Joined
- May 23, 2011
- Messages
- 185
- Reaction score
- 0
Guess I should transfer my build over here too.
Plans are D60 front, 10.25 rear, cage, boat side, back halved, 3 link front, 4 link rear. Once the cab and chassis are done ill take the 7.3 powerstroke / E4od/ 4407 from the current truck and swap them into this thing.
This got dropped off on Friday
Gutted it. Pulled the bed, fuel tanks, front clip and not shown but I pulled the front beams, and a/c heater box. I then pressure washed it inside and out.
More pics of the interior and cleaned/ gutted truck on Monday as I towed it down to the shop I work at.
I haven't ever seen these floor plates before. My truck has collapsed around where the seats are and the passenger side has a good lean going on.
Im going to be using the "better" newer heater box assy.
strip the rear axle tubes down. **** grinding the stock spring perches off. I grabbed my biggest sledge hammer and they came right off after a few good hits.
Test fit the Artec truss
Weld the truss together.. And weld.. and weld...
