Bengel
I'm looking for the best place to buy a complete rebuild kit for a blown 6.4L. The truck had a cracked piston on #1 cylinder and now its a complete overhaul. I will need all the bearing, seals, studs, gaskets, upgraded cam, and the upgraded head parts.
I also need to know if anyone knows someone that machines these blocks for oversized rings? The guy that builds all my engines does not have the correct mounting block to hold the 6.4 and it will run $700 for the tooling. Anyone know of anybody in the Cincinnati area? I am also a little concerned that .030" over bore will not clean up the bad cylinder? Can you go any bigger?
Thanks in advance for any help.
