Need help on spring codes
Atcking
Hello I have a 99 f250 sd diesel and it has a huge lift on it and I would like to take it back tonstock and do a 3-4" lift on it to run 35s in the summer and 31s in the winter
My spring code on the door reads u a
And I found 99 ex v10 stock suspension for 200.00 and the guys code is c g on his door jamb
Will this spring rate work for my truck and not slam it to the ground
Please reply when it comes to dealing with factory's stuff I'm in the dark here I tried researching the codes I found my stuff but not the excursion codes for the rate
