a_moore
Trying to enter diagnostics in H&S XRT Pro. Looked at the engine, then went to transmission to view and the unit locked up saying "establishing communication with vehicle". Waited for like five minutes then turned key off and unhooked.
Started back up and now have ABS light and the TCS light is on saying TCS OFF. I get code 0602-Powertrain Control Module Program Error
It will clear and ABS light goes out, then it comes right back on. Cleared it several times with the H&S and the Edge unit and it always comes back on. The TCS light stays on even when code is cleared.
All fuses under hood are good that I can check, I can not tell on the relays and other chit.
Help!
Help!
