Need opinion on rear suspension
doo dah
San Antonio
2012 F350 with 4" blocks, air bags, overloads, and PMF bars. Even with 2" coils up front the rear sits 2.5" higher than the front. I have 2" blocks from a 250 that I am going to replace the 4" with so the truck sits level. Question is should I remove the bags and run overloads only or remove the overloads and keep the bags. Aside from the occasional heavy material in the bed or towing my 15k pound fiver I don't go heavy very often so I don't need both. And the ride with both is not ideal.
I would loose the overloads and get daystar cups for your bags. Best of both worlds.
GarrickG
Sootie gave pretty good advice there. If you wanted to loose the blocks all together, I'd also suggest contacting Atlas Spring for rear springs.
