Need shocks on lowered F250
StrokiNDieseL
Geneva, Fl.
Running 5600lbs spring w/no rear blocks. Factory shocks in place & moved to a dirt road & ride sucks a**. Pm pricing on some kings or what every you may recommend. Thanks, Jayson.
Jomax
Arizona
Mike at nolimit sells king 2.5s for lowered trucks. Get ahold of him.
Jomax
Arizona
Didn't know king did that? I only knew you'd get an internal bump stop if you had external bypass tubes.
Jomax
Arizona
If you get them add the internal bump stop option. You can ditch the factory bump stop the way and have perfect bottom out control.
Aren't you using king hydro bumpstops to replace the factory ones??
Jomax
Arizona
Yes I am. More adjustability with the hydro bump stops but way more work.
It's worth it. The IBP shocks are great, but I would never run them without some sort of Bump stop. Shocks die fast when they bottom out completely all the time.
I'm looking forward to how you install the king bump stops. Please post pics!
