Need some help with wheel selection.
Durden86
Savannah Ga
I currently have a 2016 250 with a 4" fabtech running toyo 37/13.50s on the stock chrome 20s. I need some help figuring what aftermarket wheel I can run far as offset and backspacing goes without having to lift the truck anymore than it already is and not having to cut metal. Any help would be greatly appreciated and add some pics for reference if possible. Thanks for all the help!
Tom@BigTimeKustomz
Bayville, NJ
There are many configurations you can look at when choosing wheels. I don't like a lot of offset, so I have 20x10, -24 which gives it just a little wider than stock look. I'm running Fuel Coupler 1 piece wheels on a 2.5" leveling kit. Let me know if you find some wheels you like and I can get you some excellent pricing!!
WHY NOT
Carlyle IL
Can I run a wheel with that much offset with the 37-13.50s with only a 4" lift?
It should work, maybe have to pull back the inner fender and space out the bumper but should work. If you have to trim metal it would be a tiny amount of the pinch weld that you will never see (can be done with a dremmel tool). Not like cutting big parts of the fender or bumper that you would see from the outside. A 20x10 with a -12 offset would look good and give you a little more clearance with the wider 13.50 tire.
Durden86
Savannah Ga
Currently my setup is rubbing my radius arm pretty bad thats the main reason im looking at some different wheels
bigrpowr
<How I Fly
Administrator
it will most likely require some trimming. i ran 10.5 wides with -25 and they rubbed with 35's and 4.5" of lift .
95cobby
Houston
I'm running 20x10 -19offset with 35x13.50r20 at stock height with no rubbing.. I did space my front bumper out 1 inch and pulled the fender liners back with zip ties though. I'll be putting a 4.5" lift on soon and will be going to 37s and don't expect to rub. If anything, like already mentioned you may need to trim some off the pinch weld
Durden86
Savannah Ga
I'm running 20x10 -19offset with 35x13.50r20 at stock height with no rubbing.. I did space my front bumper out 1 inch and pulled the fender liners back with zip ties tough. I'll be putting a 4.5" lift on soon and will be going to 37s and don't expect to rub. If anything, like already mentioned you may need to trim some off the pinch weld
What all did you have to do to space the bumper out?
95cobby
Houston
You can either buy a spacer kit made for it, such as the one from kdfabworks or use stacks of washers or something similar. Any spacer thicker then 3/4" will likely need longer bolts. Basically take front bumper off, put spacers in, bolt it back on.
Durden86
Savannah Ga
Oh ok that sounds simple enough
C2tuck
North Texas
You have any pics of your truck with this set up? From the side and showing how much they stick out? Thanks
C2tuck
North Texas
Nice. You have one from the side showing the wheels and all? Just curious how they look in the wheel wells too. Also, how do you like those tires so far?
Thanks
95cobby
Houston
Thanks
Best I have at the moment. Don't miss that chrome at all lol
