New build coming MPD
blackmonster
Hi guys new build coming. I have not had my truck since Oct of last year.
New BTS 4R tranny with pcs controller.
New stock short block
Elite dual fuelers with new lines
100 over MPD inj
S474 single with .90 housing
MPD manifolds with 6.0 up pipes
There are other parts I am forgetting maybe Craig can fill in the blanks.
There are also some nice pictures of the short block painted when it was out of the truck.
Thanks Craig if you could help me out with this build thread.
Joe:thumbup::thumbup:
blackmonster
Ya I hope so. That was one of my concerns. Would the tires almost help with spool? Because they are so big and heavy it is almost like you are holding the brake to build boost.
I know the truck would be slower and heavier. What do you think?
blackmonster
No still have the One Up 550 lift lit. I got BMF rims but still sits on 40" tires
blackmonster
Everything is basically the same ex I have a complete new motor from MPD.
I changed the rims to BMF took the cab off and took the recon head lights out and put the Harly headlights back on.
I also had all the bypass shocks Satin colored chromed. They were just way to much polishing to keep clean. They look nice.
I know what I forgot! Dave at One Up is almost done the Dyna 80 rear. This rear is going to be killer. He also got me a huge custom drive shaft. You should see how big the thing is.
Craig has some pictures of it on the truck now.
O2ShootTheJ
Joe post up some recent pics of the truck, would love to see them. What BMF's did you go with? I got SOTAs and am loving them.
Strokin6.4
Hey got novakanes I'm pretty sure. I just saw it the other day. That thing has been in there FOREVER lol
Sent from my SCH-I500 using Tapatalk 2
blackmonster
I got the BMF novakanes. The turbo is the same single as Craigs but smaller housing .90 it is the S475 I think. I was going for over 1,000hp but who knows with those huge tires and lift.
It Dyno 1,080 with the old max powers but just had some bad luck with that build. I hope this one goes better! I am taking the approach this time around if the motor goes. It is because it was modded out. I just hope I can get some miles / time on this build i think I will. The guys at MPD are awesome crew and really know what they are doing.
I am confident this should go well.
dstryr
Gilroy CA
You change extreme setups more than most people change underwear....lol good luck. You must be in the oil field business right now or something similar....
blackmonster
Thanks guys. We will see how the trucks performs soon. Hopefully when Craig is finished work today he can post up some motor pictures.
Matt
Minnesota
I saw Joe's truck up close back in May with the cab off. That whole truck is insane.
Motostroker
pretty sure your big tires will put a better load on the motor for that big single, sounds like a nasty build for sure! saw your truck up the at MPD last time. nice!!
