Headlines
Newly Enlisted
New Powerstroke owner! HELP!
[QUOTE="johnp115, post: 945327, member: 10078"] I highly reccomend doing the standpipes/dummy plugs/stc fitting updates now while its apart too. no too expensive but another preventive thing down the road. This helps prevent a common hot start problem. The o rings on those parts go bad and when the oil gets warm its more fluid.. so when you turn the key it wont maintain enough ICP pressure to start (500-600psi needed to start) because the oil will drain from the bad o rings. So updating this prevents that, for me it happened out of nowhere too. Parts total were around 250-300ish if i remember correctly. And with your truck being torn apart the added labor shouldnt really be anything. Welcome to the site! [/QUOTE]
Gauge cluster face plates
Latest: crash86
Yesterday at 5:15 PM
6.0 Aftermarket
B
6.4 head gasket job cost
Latest: bowhunter
Yesterday at 2:07 PM
6.4 Aftermarket
S
6R140 surging issue
Latest: Smokin 6.0
Yesterday at 12:11 AM
6.7 Tech & FAQ
Won’t start
Latest: psduser1
Wednesday at 11:33 AM
7.3 Tech & FAQ
GT37 Turbocharger w/10 blade turbine, billet comp.
Latest: hskfab
Jun 6, 2025
Engine and Drivetrain
Headlines
Newly Enlisted
