No check engine light. No power
Derik_C
00 f250 7.3 sudden loss of power," limp mode" wont achieve speeds above 20mph. No lights on. Any suggestions?
Sent from my SM-G965U using Tapatalk
Arisley
Arlington, Texas
7.3 has no "limp mode"
Check output voltage on alternator, check fuel pressure.
Fuel pressure is not monitored by PCM.
Derik_C
Thanks for input.... will post outcomes. Anything else to check for?
Derik_C
Thank you.... i will check it out. I'll let you know.
Derik_C
Also dont necessarily watch for CEL but watch for water in fuel light if it even just temporarily comes on after you start the truck then it's time to change the fuel filter
Knock on wood... i have never seen that light on before. I have had the truck for 15 years.
Does it feel like a dead pedal?
Need to scan it with a good scanner and pull the codes to help us out. Unless you accidentally put gas in it then it will have a code.
Derik_C
Nope not a dead pedal.... starts and idles fine, it will have plenty of power for 5-10 minutes of driving.... then fall on its face, clacking and chugging. Getting it scanned now....
Derik_C
Ok.... so, no codes, and once it warms up, blows greyish smoke. And symptoms start.
Derik_C
What are you using to check codes with?
Elm327..... i get two codes
