No forward gears only reverse
Ford460power
Forks Washington
Just got a full exhaust and ******s and an SCT x4 from no limit. Loaded tunes everything was fine truck drove and ran last night, now today wouldn't start, then after it did start has no forward gears only reverse.
When you shift thru the gears it does make a clunk and noise, I'm guessing something broke internally, but before tune a d ****** truck ran perfect, never had any issues. Trucks only got 78k on it.
Lipka101
Maryland
Return to stock and see if still does it. Also could try to reload the tune.
timj
Wisconsin
You have trans files for a job 2/3 in a job 1 tcm, or vice versa. You will only have reverse. Contact your tune writer for a different trans file.
