Power Strokes
6.7 Aftermarket
No limit stage 2 intake NO GOOD?
[QUOTE="Dzchey21, post: 1213518, member: 63"] the worst part is the fix is so ***ing simple its crazy. there are mass air flow tables that you just need to rescale for the 5 inch pipe. Its crazy to me and that is not a "bandaid" of a fix that's all you have to do. I could see maybe causing an issue with the transmission like on a duramax that uses mas air flow tables to adjust pressures in the transmission but 6.7s don't respond the same... un real NO YOU DID NOT WAIST ANY MONEY! once you get the truck tuned right you will notice even MORE throttle response [/QUOTE]
OEM LED sport headlights
Latest: 99fordman18
Today at 8:15 AM
2017+ 6.7 Aluminum Super Duty
10R140 failure
Latest: PSD-BLACK-CLOUD
Friday at 1:04 PM
2010 headunit
Latest: glog
May 7, 2025
6.4 Tech
D
Latest: donaldtfreeman
May 6, 2025
6.0 Tech & FAQ
Latest: Tiha
May 6, 2025
7.3 Tech & FAQ
Power Strokes
6.7 Aftermarket
