o ring failure????
lsmith33
Katy, TX
for some reason i keep blowing injector o rings, not always the same injector an not always the same oring. what can keep causing o ring failure??
F350-6
Texas
Are you using Alliant brand o-rings? Got the injectors seated all the way and torqued down properly? Lubing them up good before the install?
lsmith33
Katy, TX
i get em tight an lube em up before install. but there night alliant o rings there motorcraft. it seems to be #8 more times than any other cylinder
