OBS Body mount bushings
KBMKVIII
Texas
So I'm trying to find core support body mount bushings.
The only ones that I have found so far have been bushings that look nothing like the ones that came out or they are $200.
I only need the front two where the core support mounts to the frame.
Does anyone have any suggestions?
Like where I can get them cheap.
Here are the bottom pieces from each side.
gnxtc2
Bergen County, NJ USA
Position 1 - Rad support
Position 2 - Under front doors
Position 3 - Rear of cab
5/8 socket is needed for the inside and 7/8 socket is needed for the bottom.
Here are the part number for just the cab bushings:
- E2AZ-5400155-A (#1 lower) need 2
- E0TZ-1000396-A (#1 upper) need 2
- E0TZ-1000396-B (#2 upper) need 2
- F4TZ-1000155-AA (#2 lower) need 2
- F4TZ-1000155-B (#3 lower) need 2
- F5TZ-1000396-AB (#3 upper) need 2
Check E-Bay.
Hope this helps
KBMKVIII
Texas
Just the information I needed!
Thank you sir
KBMKVIII
Texas
Just looked up pricing on those #s.
Uppers $75 each, lowers $40 each...
Holy balls!
I think I'll try to find some cheap aftermarket ones using those numbers.
zilla68
Moore Oklahoma
look up the results of people using other than oem, results weren't so great.
you can find the oem, just have to search
KBMKVIII
Texas
I found that Jeffs Bronco Graveyard has everything I need.
Best part is the price is less than half of the eBay ones.
OEM parts too.
Luckily they are literally 2 miles from the house as well!
Thanks everyone.
79jasper
skiatook, Oklahoma
Must be nice living that close. Lol
I usually find them to have the harder to find oem stuff.
zilla68
Moore Oklahoma
OEM parts too.
Thanks everyone.
i don't believe they have them all, they have most of them, but when I was looking there's like 2 items they don't have,
