OBS Fuel System
bigjake0524
Here is the Irate OBS Fuel system. This is a selector valve forward system. It utilizes the Irate regulated return system with Fuelab fuel pressure regulator, Parker hose from selector valve to motor back to selector. Irate fuel mounting plate, wiring harness with relay, breaker, inertia switch, Baldwin filters and bases with a Walbro GSL392 fuel pump and Parker fittings.
Full kit will be $1100 shipped!
Tom S
I would like to see what you do on the motor if you are willing to share.
smokedout250
harrisburg oregon
Tom the motor is all stainless lines with a fuel lab regulator! Works greaat looks nice and clean. If you look under the obs section I have my whole irate setup there with it installed!
