obs tymar intake or riffraff 6637 filter kit pros and cons
97strokerHD
whats everyone's opinion on them both? trying to decide which one is the best value for the money without sacrificing performance. i know the 6637 kit is almost a hundred bucks cheaper but have heard that the filter is not water resistant. is this why they sell the filter sock with the kit? heard good things about both setups, not sure which one to go with.
kramarj
Illinois
You aren't going to gain any performance by choosing one over the other.
If you do some searching, you can find a water proof filter. Don't quote me on it, but I believe the Baldwin equivalent to the 6637 is water proof and can be bought fairly cheap, like $30. Then all you need to do is get a piece of pipe, you can get a 3.5"(I think, just as long as it has a 4" O.D.) PVC union for a couple bucks. Basically you can do it cheaper than what you can buy the kit for and get the same end result.
97strokerHD
Makes sense that it would be easier to make my own Tymar style intake. Probably do the ccv mod at the same time.
old man dave
Petaluma, CA
The water resistant filter that Tymar uses is the Donaldson B085011, availiable from Tymar or other online sources.
Never have felt the need to use a filter sock with my Tymar after many Kmiles of operation including highway and offroad operation.
pros- best filtration and performance gain you can get if it is the Donaldson. swamps uses one on there engine dyno and have made close to 800fwhp with it.
cons-none
zilla68
Moore Oklahoma
It appears as though Donaldson has a high humidity version of their B085011 filter that is specially treated, typically for marine environments. It is a B085046
97strokerHD
Would it be best for me to make a one peice intake tube or just use the factory plastic tube and clamp that on the filter? Also if I did make a tube, would exhaust tubing work?
97strokerHD
Where is the best place to get the orange intake boots? Like the one that goes from the turbo to the intake.
kramarj
Illinois
If you are lucky you might be able to get your hands on a Ford intake, I believe they are discontinued. Check out Autonation Ford (formerly Tousley Ford), that is where I got mine. http://parts.autonationfordwhitebearlake.com/ Here is the part# F81Z-9C681-BA
Other than that I don't know. I ordered some aftermarket POS that didn't fit at all. So if you can't get a Ford intake, just be careful.
OBSWIZ
Wellington NV
Well....some info again that's compiled over the years.:poke:
quote:
“have a used AIS…couldn’t find a filter for it…got a FIPKI K&N system cheap…should I put a tymar on or put the AIS back on??? I was thinking of mounting a tymar to the K&N tube…what do you guys think”
The K&N element should probably be avoided in turbo-charged applications. The initial filtration efficiency is not high enough to protect the compressor impeller.
The phrase “mounting a tymar” sounds kind of like Tymar is a filter. The filter we use is a Donaldson B085011 and Tymar is a company name. Tymar Performance makes all sorts of items, one of them being the open element intake kits.
That said, the element we use would not fit on the end of a K&N FIPK system. I guess you could technically modify things to get it in, but you wouldn’t have minimal radial clearance around the filter, which should be considered very important to providing low restriction air to the turbo. Without supplying minimal radial clearance, you won’t get the positive benefits the open element system should create.
You may want to consider replacing the PVC with 4" OD metal tube once the fit is figured out. The ID of the PVC can compromise volume and we found that it made a difference with the stock turbo, so I am sure it would make a difference with the H2. The other complication we ran into using PVC or ABS was that the connections had an ugly habit of popping off. Didn't happen too often, but once is all it would take in the right conditions.
The AIS will provide excellent filtration efficiency, but will not improve overall restriction or allow much additional air flow in the configuration that Ford uses. The Tymar Intake will provide excellent filtration efficiency as well as decrease restriction to the turbo and add significant air flow.
quote:
“Tymar is going to give you better flow but AIS is going to give you unmatched filtration…the AIS plus it will last a LONG time, like 60K miles…”
Although the AIS will give better filtration efficiency, you are only talking about 1/10 of a percent over the filter Tymar Performance Intakes use at initial filtration efficiencies. Not enough of a difference to really differentiate between the two.
For the longevity, you have to start talking about restriction ranges in both stock and aftermarket applications and how dirt will affect them. AIS has a larger capacity, but not across the restriction ranges once installed on the truck. Because of the configuration you are not lowering restriction significant over stock levels, but you are receiving better filtration compared to the stock intake.
The Tymar Intake will allow lower restriction levels and lasts approximately 15K miles in a restriction range LOWER than stock. If you want to go with longevity of filter, you can continue using the same filter and will simply not experience the positive benefits of lower than stock restriction levels.
We supplied the intake systems for Granite Construction and used them as a severe duty use test. They were rebuilding Power Stroke engines at approximately 60K miles because of the fine silt in the mining beds. After changing to our system they were using the same filters with 28K mile change out intervals and only experiencing 32”h2o of restriction (yellow on your stock restriction gauges) and they eliminated the necessity of engine rebuilds and were selling the used trucks with over 180K miles on them.
quote:
“I'm using a tymar because it's cheap to setup and offers good filtration.”
Although I agree with you, your listed intake is a DIY 6637, which is neither a Tymar nor a recommended system by us. The WIX/NAPA 6637 is not a hydrophobic (water resistant) element and using it as an open element should be avoided. There are other concerns such as providing minimal radial clearance, isolating engine vibration, positioning away from rain drip channel, etc. But, I just wanted to draw a clear difference between copies, DIY efforts, and our product.
quote:
“…be sure your Tymar-type filter includes the PowerCore filter media and not some lesser media material.”
Although the PowerCore ® media is far superior to most other media, there is not a PowerCore media filter available for use as an open element. They are inserts for intake boxes and are not configure for use as filter alone applications.
The filter media is not the main attraction, but the filter configuration. It is NOT true that you cannot get the same filtration efficiencies or flow rates from other Donaldson products. It will just simply have to be larger. The PowerCore configuration allows for compact applications that have flow rates and filtration efficiencies of filters much larger. So it is the compactness of the element and not that the media processes some magical qualities.
quote:
“IMO, the FIPK tube with the heat shield and the Donaldson (aka #6637) filter combination is hard to beat for the money.”
I would probably respectfully disagree. The problem is the thickness of the stacked gauze media will not allow for a high pleat count and severely restricts the available surface area. A typical RD-1460 that is used in a FIPK system only has about 44 pleats. The Donaldson we use is not only a larger filter overall, but the thinner media allows for 202 pleats, leaving us over 5 times the surface area to pull from. This is why we can outflow and out filter a re-usable element as long as minimum radial clearance is maintained.
The problem with heat shields and routing air through intake boxes is that whenever you direct air flow, you increase restriction. Low restriction is the goal, so using a filter that has the ability to flow large masses of air and then enclosing it in a box yields very poor results. Heat shields do literally nothing. Air flow under the hood is dynamic and not static. It is moving all the time. Hot air will move right around a heat shield at the same temperature and be ingested and the only thing you have caused is turbulence.
Aside from impeding minimal radial clearance and isolation of engine vibration, a serious cause for concern is placing the filter, especially a 6637 element, under a rain drip channel for the hood. Beyond the ambient moisture that will cause restriction as it is absorbed into the non-hydrophobic media, you will be directing water towards the filter anytime the rain drip channel flows more rain than it can hold or spills over the retainer during left turns.
I’ll try to check back in and address further comments in the days to come and can hopefully shed some light on why we do what we do using the configuration we did.
Peace to all, enjoy those rigs!
__________________
Hydroscopic means it absorbs water. Hydrophobic is water resistant. Easy to remember because "phobic" comes from phobia, meaning to be scared of or to repel.
Anyway, both of those filters are hydrophobic. The 085046 filter is for high humidity applications. This has little to do with the hydrophobic capabilities and deals with micro biotic growth since constant high humidity, think of boats that are always in the water moored to a dock, will have greater abilities for mold and such to develop on them.
It should be noted that the 085046 filter is a LOT more expensive and there is no air flow or hydrophobic benefit over the 085011.
Filter covers:
Total waste of money from a performance perspective. They do everything they are not supposed to do. They lower flow by causing additional restriction, have no surface area for high volume, and are unnecessary if you use the properly rated element for the application.
From a filtration view, they can increase filtration efficiency in applications where the filter used has very poor filtration efficiency (ie: reusable/cleanable elements, K&N, AFE, etc). However, they do it will a substantially smaller surface area that has basically no capacity to speak of. It will also measurably affect your flow rate negatively from the increase of the restriction, because you are, in affect, adding an additional layer of filtration with no surface area.
Think about these numbers:
Surface area of Donaldson I use on the Tymar Intake: 4,000 sq in
Surface area of a K&N conical style: 975 sq in
Surface area of a filter cover: 150 sq in
Donaldson has 4 times the surface compared to the K&N, which is significant in its own right, but 270 times the surface area compared to the filter cover, making a filter cover nothing but a hindrance. Filter covers originated from reusable elements inability to filter the air of a dusty environment. Using a proper filter with a proper filtration efficiency and you don't need to worry about it.
Same thing with the guys using them to protect an open element using an improper filter from experiencing water mist. If you use a proper filter for the application that uses a hydrophobic (water resistant) filter media you don't need additional layers adding restriction and lowering flow to gain protection. Again, use a proper filter you don't need to worry about it.
__________________
Filter covers:
holy chitballs that was a long post. haven't seen ya post in a while.. good info!
brewer
Cary, I agree with you on the filter covers. Just curious why you say AFE filters have poor filtration efficiency? The AFE big boost (6637 "equivalent") flows 850cfm vs the 6637 at 425 cfm.
Sorry to the OP if this is too much of a derail.
zilla68
Moore Oklahoma
I have a pete's cover and I don't see why you say they are worthless. I pull mine off and wash it out, and my filter is still like new, and when I wash the cover its filthy, so it must be doing something for me
old man dave
Petaluma, CA
The filter cover is a restriction compared to the bare filter. The Donaldsons last a long time without a filter cover. I usually do a full prep before dynoing my truck including a fresh filter. I forgot once and I dynoed my truck after a week of offroading and got the same 400hp numbers as aways. Needless to say, I don't believe in covers on a Donaldson.
old man dave
Petaluma, CA
Filtration efficiency is about how many small of particles get filtered out. Generally, the higher the airflow, the more small stuff gets through the filter for the same size filter.
Does the aFE use the same flow method as Donaldson as far as number of particles of the same size getting through at the same airflow? Otherwise, its comparing apples and oranges if they don't.
old man dave
Petaluma, CA
This is the Black Hose Update Kit that the factory came out with when the orange hose setup didn't turn out so good.
It has a black plastic hose (like a heater duct), a replacement plastic CCV adaptor, clamps and hardware to mount for a complete conversion kit to replace the orange hose and aluminum CCV adaptor. It worked pretty good for me. Also worked with a Tymar.
The black hose was availiable by itself if you wanted to make your own 4" CCV adaptor out of a short section of 4" exhaust pipe. This also worked on a buddy's truck.
I have the part numbers as:
Black hose with clamps: F81Z-9C681-BA (Need to make CCV adaptor) $58.61
Black hose full intake kit including CCV adaptor: F7TZ-9C681-AA $96.83
Current pricing from Sunrise Ford (a sponsor here and has decent prices) and apparently still availiable.
