p0603 code
TARM
Doesn't it soft code that error everytime you switch between the your various tunes?
Arisley
Arlington, Texas
That's not your wastegate blowing, that is an overboost code, when you hit 28psi, the motor defuels.
All TS chip tuners can stop the defuel, some can even stop the light.
littleredstroker
where the antelope play
Took me 4 hours . With a dinner break and it being my first time Doin anything to a SD. honestly if you have half a brain and some basic tools its cake, maybe take an hour . The way I did mine was pulled the compressor housing. Put 3/8 impact on the nut. And just bumped the trigger a couple times to loosen. When I installed I took exhaust off turbine housing , grabbed a 3/8 wooden dowel with a rag wrapped around it and held the shaft from spinning, then tighten to 120 inch pounds ( if I'm.wrong someone will tell me I'm sure)
Sent from my HTC PH39100 using Tapatalk 2
