P0700 p0710 p0713
EShore,MD
Okay so truck is 06 f250 6.0. Had p0700 and 0710 so I ordered a sensor and replaced it. Cleared codes and checked dtc again now with the new sensor I have p0700 and 0713. Ohmed the sensor it's showing 50.55 ohm. I ohmed the connector that plugs into the sensor it ohmed 1.6. I turned the key on and checked voltage at the connector it was 5.55vdc. When I checked continuity on the two pins with key off I got nothing. The orange/black wire was not shorted to ground and the orange/white wire had continuity to ground which tells me it's good. Am I correct in thinking the tcm maybe the issue?
