P2138
TD-5
British Columbia Canada
Truck has been stored in the barn since October. I Started it yesterday to move it to the shop for some maintenance items. Truck fired right up no problem even with the cooler temp -10c (14F). As soon as I touched the throttle I got a wrench light & RPMs jumped up to about 1500. Depress the brake & & it went back to idle but throttle pedal is dead with foot on the brake. Take foot off the brake pedal & it revs back up.
Threw code P2138 – throttle pedal position sensor/switch D/E voltage correlation.
Shut it off & restart & idles normally until the throttle is touched, Then same thing again. Put the truck in the heated shop cleared the code & after 3 hours fired it up & all is normal. Can cold temps affect a weak throttle position sensor? Its’ never acted up in the past.
TD-5
Can't offer any words of wisdom as my fault never returned for me to look at...... at least not yet. I have attached the pin point test section for the APP from the PCED service manual. Gives you some things to look at.
  • 2008 64 PCED - Pinpoint Test AG - Accelerator Pedal Position Sensor.pdf
