Pistons??
jtlane
Has anyone had to have their pistons cut down? The pistons I bought was .1 shorter I told the machine shop not to deck it no more than .1 it came back with .38 and to .4 protruding the deck
Magnum PD
VA
Think your missing some zero's.
.010 decked pistons. I had to get .066 thick headgaskets.
Magnum PD
VA
I gotta check to see what kind of protrusion the pistons are suppose to be.
Magnum PD
VA
Cometic sells different size thickness gaskets for their mls. Maybe that can help.
DZL JIM
North East Ohio
You don't want to go too much thicker than stock on mls Cometic gaskets, they won't hold.
Back in the day I had had several sets of 7.3 pistons shaved off the tops. This lowers compression changing the power/torque curve. But since then research has proven that bowl work is a better way to go.
thatdude
Alot of guys are really big on this, I've argued up and down that this is retarded.
Some guys will deck down .040 and still do .030-.045 of valve relief. It's silly, no reason for it at all.
thatdude
You shouldn't have to cut down pistons. So this isn't a typo, you have almost a half inch of protrusion? If I'm not mistaken it's suppose to be .014 to .031. I don't understand how you can be at .4... Almost sounds like you have a factory defect with your pistons to have that much protrusion.
As for valve relief, that depends on the cam. I think I went with a stock deck height and .036 valve relief.
jtlane
The machine shop cut it down way too much I told him I could not go over ten thousands I started off with .021 all the way a cross the board now it's as much a .04 I had .01 shorter pistons
thatdude
No idea what max is. I've seen guys deck them past .040. Ideal protrusion is right around .022-.025.
Hard to know max without assembling the rotating assembly in the block.
I'm just confused about your post because you said you had almost a half inch of protrusion and that's not right at all, that's like factory defect piston.
bluedge8
Champlin MN
He didn't post the numbers correctly at first, he has since used correct numbers.
thatdude
your attitude is annoying for a newbie.
Anyways to the op. I thought protrusion was .014 to .031. I looked it up, it's actually 0.010 to 0.031. I'm assuming with your numbers you got pistons straight from Mahle and not in a ford rebuild kit? (those tend to be higher for some reason?).
jtlane
The Machine Shop took to much off my block I put all the pistons and done the measuring I started off with .021 cause my pistons are .01 shorter now I'm at .04 I told the machine shop that I could not go over .01 off the block I got it back now I'm at.04
