Hope this is the correct forum section.
If all goes correctly I'll have my car sold and be buying a 09 Harley F250 next week. Meeting with the owner tomorrow to check it out and test drive the truck.
Couple things, the owner said the radiator has cracked about 10k miles ago and was replaced under warranty. I know this is a some what common issue with 6.4 trucks but was under the impression it was an early 08 issue. Those of you that have delt with this on your 6.4 was the OEM radiator replacement a complete fix or do I need to look aftermarket for a better quality unit?
Second, the trucks at 51k miles currently. Owner stated the factory warranty was up at 60k. Do the 6.4's have a 100k drive train warranty? I can throw a extended warranty on the truck no problem, but want to make sure the drive trains covered for a good while.
Any heads up on additional things to look for? Thanks in advance guys..
Jon
Jon
