Power window help!
Joshf250
My passenger side window will not go up or down, I have replaced the switch and motor. I’m getting power to everything, so I don’t see what I’m missing here? Is there any ground wires that relate to the power windows?
jpow95
Can you control the window with the driver side window switch
Joshf250
No I can’t, I’m getting power on that side too. If the switch on the driver side is bad will it cause the other side not to work?
jpow95
I know on the 7.3 if the switch is unplugged it will not work on the passenger side has to complete the circuit
jpow95
Do you have power at the have you checked Power at the window motor
Joshf250
Yes I have power at the motor itself which has me stumped
jpow95
And you said it’s a new motor do you have a power probe to test the motor on it’s own out of the circuit
Joshf250
I’ve put 12 directly to the motor just to check and it worked, I at night the window switch still doesn’t light up even with the new one
Mesa, AZ
As stated previously, the master window switch needs to be working to complete the circuit for all the other switches.
Joshf250
Put power or power and ground directly to the motor?
Sent from my LG-E980 using Tapatalk
I’ve put power and ground to the motor and it will work. I’m thinking it’s the switch on the driver side panel now. If I hit the switch on the passenger side my test light will light up on plug saying I’m getting power but if I go hit the switch on the driver side I get nothing. I guess if the driver side switch is no good the circuit can’t be completed. So I’ll get a new switch hopefully tomorrow and see what happens.
95GTSpeedDemon
Yes
Then its probably the switch. The drivers door harness ground tends to break and causes weird stuff to happen when it sources an alternative ground thru other parts.
Joshf250
Where is that ground located? I’ve checked all the grounds that I can find but may be over looking something
