Power
Twan
Berthoud, Co
How much power, just a educated guess should 175/30% injectors, a Powermax add on stock tuning?
MrOneEyedBoh
I wouldn't use a power max turbo on stock tuning. It's been known to run hot and Maggy. Then pair that with bigger injectors? You won't be taking advantage of either the injectors or the turbo fully.
Twan
Berthoud, Co
I know you won't get full use, asking so I have a good base line.
I would have thought it would be a good 50jp over stock still.
Egts are fine, lag is about the same as when tuned.
