Precision PT106,
Erikclaw
Central CA
Precision PT106, Ball Bearing, F Trim Turbine Wheel (This turbine wheel is smaller than normal and was designed for a wastegate to control the speed of the 106, so they need to be careful to not overpseed turbo-FYI), 1.0 A/R Turbine Housing, Polished Compressor Housing, Comp Housing machined for 5" Boot
This 106mm was going to be the atmo for the tripple set up but isn't going to happen. It was converted to a ball bearing and has never been used since the conversion. It is basically brand new.
Asking $3750
