Question: Housing options..
silverpsd_06
Wellsville KS
Ok i can get a couple 91mm atmospheres for my setup now that the funds have been gathered.. First option is new from forced inductions, t6 1.23 a/r 1300 bones.
Second is a schwitzer s4t thats been modified to a 91mm or even bigger such as a 95 or 98. T6 1.45a/r housing only 1k for it new.
What do you all think would work better for my compound setup 1.45 too loose of a housing?
The secondary turbo is a gt4094 r with a .84 housing on it for reference..
Can i find a tighter housing for the s4t? Or does anyone have any helpful info??
Thanks guys
NyCowboy87
Arkport, N.Y.
I have a 1.14 for a s4t that I want to get rid of. I ran a 88mm one when I had my twins. It worked great and the set cleared 400/200's to a good haze in the hot tune and absolutely no smoke in the street tunes.
You also need to look at the turbine side as it is equally important. It will play a big role in how it spools and how well it will flow.
silverpsd_06
Wellsville KS
So its a general concensus that the 1.45 is gonna be too loose to spool properly in a compound setup? How much would it take to get that turbine housing from you?
