Quite a few Audio System items.
MPTonyT
Tampa Bay, FL
I have decided to clean out the garage and get rid of the "One day I'll use that" pile. All of this stuff is in great working order. .
Everything will be shipped the next business day after payment via UPS ground. Prices shipped are to the lower 48.
Memphis 16-ST300.4 / 4 Channel 75 x 4 @ 4 Ohms
Has a few cosmetic blemishes but works perfectly. 150.00 Shipped
Alpine V12 MRD M605 / Mono Sub Amp 600 x 1 @ 2Ohms $175.00 Shipped
Amp has cover (not pictured in the next photo but is in another photo down bleow)
MPTonyT
Tampa Bay, FL
More....
Alpine MRV-F345 / 4 Channel 75 x 4 @ 4 Ohms - 125.00 Shipped
Memphis 16-MC250D / Mono Sub Amp 250 x 1 @ 2Ohms - $50.00 Shipped
A few cosmetic blemishes, Gain pot does not stop at max it will reset to min when turned passed the max adjustment.
Alpine Type R 6.5 Coaxial speakers / 2 Pair - $50 Shipped Per Pair
MPTonyT
Tampa Bay, FL
More...
Phoenix Gold Ti210D4 / 10" Dual voice coil subwoofer 4Ohm - $100 Shipped (sucker is heavy)
Phoenix Gold BassCase8 / 8" Subwoofer in a ported enclosure 4Ohm - 85 Each Shipped
I had both of these behind the seat in my 2005 CrewCab with rear power window.
Phoenix Gold SD Radial 300.4 / 48 x 4 @ 4 Ohms - $85.00 Shipped
Phoenix Gold Ryval 12" Woofer - Single Voice Coil 4Ohm 600W - $35 Shipped
dsberman94
Pennsylvania
What's the depth on that Phoenix gold sub? Is it fairly shallow or no? Want it for a shallower truck box.
Koda22
Ruidoso, NM
I'm maybe interested In The two 8inch subs, but few questions. Did you have to move the seat any to fit them? What did you use to power them?
MPTonyT
Tampa Bay, FL
I did not have to move the seat at all. If you look, one of them the the grill is slightly bent. The seat did that when fully locked up. I can replace the grill but it will most likely do the same thing. Also, I used the Alpine 600W amplifier above to power them. The Other Alpine was on the door speakers (6.5" Type R's) listed above as well. I can even include a set of adapters (5" x 7" to 6.5") If you wanted to go that route.
MPTonyT
Tampa Bay, FL
All but the PG 10" woofer has sold. I plan to use that though in my wife's truck when i build a different fiberglass enclosure in her vehicle.
