radiator busted need help
1badpsd
lebanon,tn
My radiators busted on me,mine has the internal trans cooler and the only one I can find is in an 01 with a 5.4.its still in the truck but everything looks the same, so will ir work in my truck or are the gas different?
1badpsd
lebanon,tn
Are y'all positive? Because when I looked it over it looks the same height width and depth as mine
1badpsd
lebanon,tn
Well like I said its still in the truck and everything looks exactly the same as it does in mine the plastic tanks look the same and the core from as much aa I can see looks the same.
Marauder
Arizona
Freakin size matters!
The 5.4 core is 1 3/8 inch thick.
The 7.3 core is 2 1/16-1/8 inch thick.
They look the same and either will fit either truck.
Except!
The 5.4 radiator will not, I REPEAT, Will Not Cool the 7.3.
Put your tape measure and new found information to work......
Tom S
I would also suggest you put in a new radiator not something out of the yard.
