radiator front mount bushings
wildbill963258
In Lawrenceburg, Kentucky
anybody have a set of radiator front mount bushings or know where I can get a good set from? i replaced my radiator core support but i cant finish the job because my radiator front mount bushings rotted with the core support i had to cut the old bolts off just to get the old rot out tof the way and the bushings have pretty much welded themselves to the mount as well as whats left of the old bolts
wildbill963258
bump i need an answer soon please because the longer i leave my frontend half complete the more issues i will have down the road (plus i hate the look of it with no grill or nothing on the front except headlights and turn signals)
79jasper
skiatook, Oklahoma
Probably not the best option, but Iirc, these aren't made anymore.
I have used some all thread, big washers, and poly mounts.
Sent from my SM-T537R4 using Tapatalk
Parker, TX
I can't find a Ford part number. I made mount bushings for my intercooler using some fender washers, bolts, and swaybar endlink bushings I had lying around. Cheers!
danielzink
When I replaced my core support last year I used the LMC stuff.
All cushions, bolts, washers...etc.
I also ground off the rivets and replaced the core support brackets on the frame (the new LMC brackets come with nuts and bolts to replace the rivets).
Dan
