Raising desired fuel per load range
Kind
Anyone mess with raising the desired fuel at any given load range. For example instead of 130mm^3 only being at the top load range maybe bring it down to the 600-700 load range... Then even the rest out.
ckrueg
Belding MI
Don't see why that wouldn't work. On my tunes max pw is commanded at 120 mm^2 which is around 650 tq iirc. You just will want to make sure your commanding max boost, timing etc at the same load range.
